Nettl-Hereford
Feb 09, 2022Aspirant
WAC540 - Not connected to Insight cloud after firmware update.
Hi Have updated to V9.5.5.4 and now neither of my WAC540s will connect to insight cloud, just says Status: Device failed to connect back Please advise where to start looking to resolve issue. K...
schumaku
Feb 09, 2022Guru - Experienced User
Reboot. Simple if your PoE switches are Insight managed.
- Nettl-HerefordFeb 09, 2022Aspirant
Have tried a couple of reboots and no luck.
- schumakuFeb 09, 2022Guru - Experienced User
Do the WAC540 get PoE power (only one port is PoE)?
Do the WAC540 get IP configs assigned from your DHCP server (typically on the router)?
Can you ping the WAC540 IP addresses?
Can you reach the WAC540 local Web UI by using a Web browser using http://[ip-address]/ ?
schumaku wrote:Do the WAC540 get PoE power (only one port is PoE)? 1 is POE and 1 is a power adaptor
Do the WAC540 get IP configs assigned from your DHCP server (typically on the router)? No static IPs
Can you ping the WAC540 IP addresses? Yes and I can access via local LAN
Can you reach the WAC540 local Web UI by using a Web browser using http://[ip-address]/ ? YES
See answers above.
