module12
Nov 08, 2021Apprentice
WAC540 connected to unmanaged switch connected to Sky Q Hub/Router
Hi, I have this setup: Sky Q Hub (with all WiFi features turned off) TP-Link Unmanaged 8 port switch with 4 ports PoE+ (ports 1-4) My non-PoE devices connected to ports 5-8 on the TP-Link, ...
Nov 08, 2021Guru - Experienced User
What tp-link poe switch is it?
what happens if you power the WAC540 of a power supply and not from poe?
- module12Nov 08, 2021Apprentice
It's the TP-SG1008P v4 (which has PoE+). Haven't tried power supply as the WAC540 doesn't come with one and didn't think it would be necessary.
- plemansNov 08, 2021Guru - Experienced User
Was think of it for just testing. It wouldn't be the first POE switch that wasn't supplying full power.
Also make sure to have the poe suppying port 1 on the WAC.
The power supply is a 12VDC 2.5A power supply. You might have one sitting around from an old router (or even current one) for testing.
Yep, Port 1 on both WACs is used (port 2 is unused). Port 1 on the PoE switch as well. According to the specs, the TP-Link provides 30W per port, max 64W. I have no other PoE devices plugged in so cause an overflow, and even it I did it would surely just shut down power knocking the WAC540 off, not make the Sky router go into panic mode and basically brick all ethernet ports!
