Preformed2019
Mar 31, 2022Tutor
WAC540 WIFI Scheduling issue
Hello guys I have 5 WAC540 AP devices, which I need to set a scheduled SSID availability. there is an option on the SSID setting to set a schedule and it will let you choose the time you want to se...
Mar 31, 2022Guru - Experienced User
I don't have one to test with but can you change the minutes?
So set it from 00:01 to 23:59?
- Preformed2019Mar 31, 2022Tutor
unfortunately you can not set minutes, it only works with hours..minutes is always on 00. and no way to edit them.
