JCC83's avatar
JCC83
WAC720 and WC7500 over site-to-site VPN
Trying to setup WAC720s across a site to site vpn from the WC7500.  The guide says you have to preprovision the WAC720s to get them to work across a vpn, but does not explain what is meant by that.  ...
  • JCC83's avatar
    JCC83
    Aug 31, 2018
    Was able to get this up an working with no issues.  The WC7500 documentation calling for using DHCP option 43 or preprovisioning the APs was a little missleading.  The APs were not able to update their firmware over the VPN (kept timing out around 20%) even though the connection was good enough that I could download the firmware needed from the controller from my PC in a matter of seconds.  Upgraded the APs from my local PC, and went ahead and put the IP of controller in as well.  I guess had I "preprovisioned" the APs with the right firmware by connecting them to the controller then they may have connected right away or just required me to login to the AP and add the IP of the controller.  Either way the documentation saying preprovision was required and reccomending DHCP option 43 were not actual steps needed.
