Arctic_Hare
Jan 23, 2023Tutor
WAC720 connection issues
I have a single WAC720 (latest firmware 3.9.1.13) that normally has approximately 20 devices connected to it (split between the two bands). I am having problems with one device on the 2.4 GHz band. T...
Jan 23, 2023Guru - Experienced User
Wow that device does have a lot of complaints on the forums about it.
Plus if its the only device with issues, makes me a bit more focused on it.
2 things you could try.
1. did you try setting up a separate ssid for the neeo device to see if it'd have issues on a separate ssid?
2. the only other thing I'd try is see if you have an old router sitting around. Or access point. If its an old router, set it up in access point mode and connect the neeo to that. See if it has issues on the other one.
IoT devices can be a pita because the manufacturer doesn't always fix issues with them. i had one smart plug I threw away because it constantly took my network down. (suspected some weird loop issue).
Arctic_Hare
Jan 23, 2023Tutor
Regarding suggestion #1: Can one adda second SSID on the 2.4 GHz band on the WAC720? I thought it would only use on SSID for 2.4 GHz and one SSID for 5 GH
Regarding suggestion #2: I am running such an experiment right now. I turned off the 2.4 GHz radio on the WAC720 and turned on the 2.4 GHz radio on my ISP router (using same SSID and PW); This is not ideal because the ISP router is much further away from the area where the remote is used, but it is still getting a RSSI of 57 - 67, so not too bad. It can take up to two weeks for the problem to present and I just started this experiment earlier today.
The NEEO costs the better part of a grand, so I won't be just throwing it away... sigh. FWIW, Control4 is retiring the NEEO and replacing it with the Halo Touch, which has 5 GHz capability... but, that is another $1,000.
