alfrede3
Sep 26, 2016Tutor
WAC720 Stability Issues
I have posted this issue before thinking I had a solution. Have to cycle power on both of my WAC720 access points at least once per week. We have tried different firmware versions, setting specific wireless channels, default settings. Just cannot figure out how to make these devices reliable. Two devices running in Ensemble mode with same SSID.
Hi alfrede3,
It's great to hear that! There must be something wrong with the ensemble mode. I think it's safe to say that we can now mark the post as resolved, I'd like to suggest to you to mark the appropriate post on the thread as "Accept as Solution" so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- JohnRoNETGEAR Employee Retired
Hello alfrede3,
It would be better if you open a ticket with our Support Team. I do not see a logged issue similar to what you are experiencing, it is best to let the engineers check if this is a bug or an isolated issue. They may ask you to run a network diagnostic software (like Wireshark) and send the captures to them so that they will identify the issue.
Thanks,
- thchengNETGEAR Expert
Hi,
What you described is definetely not what is expected. WAC720 is quite a stable product, and if you have to reboot once a week, it is definetely not a normal behavior. I don't know your network. Are you powering the AP with power adapter or PoE. If you are using a power adapter, did you use the one that is recommended to be purchased as an accessory for this AP. Note that the power adapter that normally comes with the other NETGEAR AP's are not strong enough to power the WAC720.
Our support can definetely help you.
Cheers,
Thomas
