azizrj's avatar
azizrj
connecting 3 WAC720 using wc7500
I have (new setup and new netgear family)   three VLANs 10,20 and 30 configured on M4100 switch and I have  wc7500 in play and all behind a sonic wall.
The three SSIDs wouldn't not  work if the three APs are on. WIfi works great with only one AP is active. each vlan gets it iP (DHCP) from the firewall.
each AP is assigned to different group.
Thanks in advance for your feedback
  • azizrj,
    Thanks for the update.  I'm glad to know that the APs are working fine. :)
    Since the APs are working fine and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi azizrj,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Are the 3 WAC720 directly connected to the M4100 switch or to the WC7500?
    b. If ever the 3 WAC720 are connected directly to the M4100 switch, are the ports where the 3 WAC720 set as tagged ports with a PVID of 1?
    c. What is the current firmware of the WC7500 and the M4100 switch?
    Kindly read the High-Level Deployment Scenarios from pages 44-51 of the WC7500 user manual here as a guide.
    DaneA
    • azizrj's avatar
      azizrj
      Thank you for replying:
      I have three APs on M4100 (PoE)
      on M4100
      I untagged native vlan 1
      I have:
      port 3 on M4100 untagged and plugged to WC7400 port1
      port 12 to Sonicwall (x4) tagged
      port 5 for vlan 10 tagged vlan membership port 3 (U) port 5 (T) and port 12 (T)
      port 6 for vlan 20 tagged vlan membership port 3 (U) port 5 (T) port 6 (T) and port 12 (T)
      port 7 for vlan 30 tagged vlan membership port 3 (U) port 5 (T) port 6 (T) port 7 (T) and port 12 (T)
      firmware on WC7500 it is maybe one level down. so it goes for the APs. I am running the office on one AP that is running for now
      I'll be going in and check the firmware
      • Prashanth_MP's avatar
        Prashanth_MP
        NETGEAR Expert
        Hi Azizrj,
                  I would like to help you in setting up your APs. Please do give us some more information.
        1. Are VLAN10, VLAN20 and VLAN30 are the VLANs used for 3 SSID's? or management VLANs?
        2. If you are using these VLANs only for SSID's , then take the vlan confguration of the port where you have the working AP connected and config same on the ports where two other APS are connected..
        If my understanding on your expectation is correct then following vlan configuration on the switch ports where devices are connected should work
        Controller---- VLAN 1(UT)
        firewall(DHCP server)--All VLANs tagged(10T,20T,30T)
        AP1---vlan1(UT), vlan10(T), vlan20(T),vlan30(T)
        AP2---vlan1(UT), vlan10(T), vlan20(T),vlan30(T)
        AP3---vlan1(UT), vlan10(T), vlan20(T),vlan30(T)
ProSupport for Business
