redtech116
Jan 28, 2017Aspirant
WAC720 LOCKING UP
Having a radom lockup issue...on two different wac720 units at different sites the wireless just stops, can not log into the unit, disconnect/reconnect ethernet has no effect. Have to power cycle ...
RaghuHR
Mar 07, 2017NETGEAR Expert
Please refer the page 69 -70 on how to setup syslog server.
http://www.downloads.netgear.com/files/GDC/WAC720/WAC720_730_UM_EN.pdf
You can install any free third party syslog server on windows/linux box.
thanks
Raghu
DCMData
Mar 08, 2017Tutor
Lots of debug stuff tonight...Have reset it 4 times today...
[Mar 9 2017 04:28:28] [info] hostapd[1343] STA 74:f0:6d:20:4d:08 deauthed from BSSID 2c:30:33:98:8f:a0 reason 3: STA is leaving IBSS or ESS
[Mar 9 2017 04:28:28] [info] hostapd[1343] Assoc request from 74:f0:6d:20:4d:08 BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 9 2017 04:26:29] [info] hostapd[1343] STA 74:f0:6d:20:4d:08 deauthenticated for reason 15: 4-way handshake timeout
[Mar 9 2017 04:26:29] [info] hostapd[1343] Station 74:f0:6d:20:4d:08 had an authentication failure, reason 16
[Mar 9 2017 04:26:25] [info] hostapd[1343] STA 74:f0:6d:20:4d:08 associated with BSSID 2c:30:33:98:8f:a0
[Mar 9 2017 04:26:24] [info] hostapd[1343] STA 74:f0:6d:20:4d:08 associated with BSSID 2c:30:33:98:8f:a0
[Mar 9 2017 04:26:24] [info] hostapd[1343] Assoc request from 74:f0:6d:20:4d:08 BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 9 2017 04:26:24] [debug] hostapd[1343] station: 74:f0:6d:20:4d:08 deauthenticated
[Mar 9 2017 04:26:24] [info] hostapd[1343] STA 74:f0:6d:20:4d:08 deauthed from BSSID 2c:30:33:98:8f:a0 reason 3: STA is leaving IBSS or ESS
[Mar 9 2017 04:26:24] [err] hostapd[1343] trying to deauthenticate to station 74:f0:6d:20:4d:08, but not authenticated
[Mar 9 2017 04:26:24] [err] hostapd[1343] trying to update accounting statistics, station 74:f0:6d:20:4d:08 not found
[Mar 9 2017 04:25:22] [info] hostapd[1343] Assoc request from 74:f0:6d:20:4d:08 BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 9 2017 04:25:22] [debug] hostapd[1343] station: 74:f0:6d:20:4d:08 deauthenticated
[Mar 9 2017 04:25:22] [info] hostapd[1343] STA 74:f0:6d:20:4d:08 deauthed from BSSID 2c:30:33:98:8f:a0 reason 3: STA is leaving IBSS or ESS
[Mar 9 2017 04:25:21] [info] hostapd[1343] Assoc request from 74:f0:6d:20:4d:08 BSSID 2c:30:33:98:8f:a0 SSID ComeTakeIt
[Mar 9 2017 04:25:21] [debug] hostapd[1343] station: 74:f0:6d:20:4d:08 deauthenticated
[Mar 9 2017 04:25:21] [info] hostapd[1343] STA 74:f0:6d:20:4d:08 deauthed from BSSID 2c:30:33:98:8f:a0 reason 3: STA is leaving IBSS or ESS
