redtech116
Jan 29, 2017Aspirant
WAC720 LOCKING UP
Having a radom lockup issue...on two different wac720 units at different sites the wireless just stops, can not log into the unit, disconnect/reconnect ethernet has no effect. Have to power cycle ...
RaghuHR
Mar 17, 2017NETGEAR Expert
Thank you. Do you have the console connected to AP? If yes please give the console output by executing these commands? Please execute these commands before you start test to till you hit the issue
echo 8 > /proc/sys/kernel/printk
echo Y > /sys/module/printk/parameters/time
You need to redirect all the console log to to file and send it.
You can refer the folloing video how to redirect console out put to a file.
the https://www.youtube.com/watch?v=ZvNNoP7tivQ
When hang happens did you tried hard factory reset ? Was your AP responding for that? these are important data points for us debug further.
Thanks again.
DCMData
Mar 17, 2017Tutor
I don't have a console connected to the AP, but in my testing I did do a factory reset and reprogrammed from scratch. Also in above I stated that I called support for this issue and they replaced the access point under warranty, so this is a different access point havig the same issue I had before. I did a factory reset on both before re-programming them. I did not restore a backup.
The AP is hanging on the ceiling, so I did not do a reset with the button because it is hard to reach, I just did a power reboot from the POE injector then went in and factory reset it. I did not do it from the button.
I can try that next time if you like, it is working better and has only locked up once since I got all the Samsung devices off of it, None of which are an S7.
