PC-David
Aug 09, 2021Aspirant
WAC720 rebooting for no apparent reason
I have 10x WAC720 AP's in an ensemble, all on the latest firmware (3.9.1.13), and they seem to randomly reboot causing all connected clients to drop or switch to another access point. They don't all ...
Aug 10, 2021Guru - Experienced User
have you been able to isolate it to a few devices or is it everyone of them?
Reason I ask is if you can isolate it to a few, maybe its the POE connection causing the issue.
with multiple devices having the same issue, I wouldn't be looking at a hardware issue with the router.
I'd either be looking at the firmware or whats powering them.
PC-David
Aug 10, 2021Aspirant
It is unfortunately all of them. Some do it more than others, but they all do it.
- plemansAug 10, 2021Guru - Experienced User
Did it just start recently or how long has it been going on?
I'd try downgrading the firmware and getting in touch with a mod from the business side.
If its a firmware issue, it'd be good for them to know.
Those devices do have a lifetime warranty but its doubtful that all 10 would have hardware failure at once.
- PC-DavidAug 10, 2021Aspirant
It's been happening for at least the last year. I can try downgrading the firmware if I have time this weekend.
- DaneAAug 11, 2021NETGEAR Employee Retired
Kindly answer the questions below:
1. From your initial post, you mentioned “The AP's are powered from a mix of PoE switches (HP and Dell) and injectors around the building, all on battery backups.” What is the model of the switches where the APs are connected and how many APs are connected to each switch?
2. Are there any other PoE devices being powered by the switches aside from the WAC720 APs?
3. Are there any PoE related logs being seen on the switches?
Kindly provide the syslogs when reboot is seen. Also, please get the WAC720 AP logs from the web-GUI. Kindly upload the syslogs and AP logs via Google Drive then send the Google Drive link to me via private message so that I can download it.
DaneA
NETGEAR Community Team
