murphyto
Jul 12, 2018Aspirant
WAC740 work without wireless controller
I am planning to get a WAC740 with a Cisco PoE router (RV345P). Can I directly connect the WAC740 with RV345P without any wireless controller.
many thanks
- Jul 12, 2018
Hi murphyto,
Welcome to the community! :)
The WAC740 cannot be configured as a standalone access point. It is designed to be managed using a NETGEAR wireless controller (such as the WC7500, WC7600 or WC9500).
Since you need a standalone access point, you may want to check the WAC510 or WAC505 access points. Both of these access points supports the IEEE802.11ac Wave 2 standard and it can be managed either through its web-GUI or via the Insight App. For more information about the WAC510 or WAC505 access points as well as its comparison to other NETGEAR ProSAFE access points, kindly check their data sheet here.
To know more about other NETGEAR ProSAFE access point models that would fit your network requirements, kindly access the links below:
NETGEAR ProSAFE Access Points Selector
NETGEAR Product Catalog 2018 - see pages 66 to 70
DaneA
NETGEAR Community Team
DaneA
Jul 12, 2018NETGEAR Employee Retired
Hi murphyto,
DaneA
murphyto
Many thanks for your useful reply
