donnerluetjen
Oct 17, 2023Tutor
WAX 610 API?
Does the WAX 610 access point have an API implemented, or any other way of programmatically change a setting (wifi key for guest wifi)? Thanks
- Oct 19, 2023
Essentially, SNMPv3 is a good option for any network, and should definitely be used on public and internet-facing networks to protect against security risks and threats. SNMPv2 should be limited to internal networks, eg. where you can restrict the admin access to a limited audience only, for example in a dedicated management VLAN.
Netgear WAX in general, and specifically the WAX6xx, don't offer any CLI - everything is either Web or Insight Cloud managed. Ergo no ssh access, except of some private reverse ssh access for Netgear diagnostics and support purposes.
schumaku
Oct 18, 2023Guru - Experienced User
SNMP should allow to define/change a PSK for an SSID on a VAP.
