jmacchi
Oct 25, 2025Aspirant
wax202 no ethernet connection
Hello, I have a wax202(AX1800) I was using as an access point then decided to move it to main router function so I did a reset. I don't know if its related but now I have no ethernet connection(no o...
Oct 25, 2025Guru - Experienced User
When you try to connect to the wifi, what error do you get?
Or if you try wiring a pc into a lan port
Did you fully reset it? Make sure while its powered on to push and hold reset for up to 15 seconds. The lights should change.
That should get you back to the default to where the information on the sticker is correct.
