jmacchi
Oct 25, 2025Aspirant
wax202 no ethernet connection
Hello, I have a wax202(AX1800) I was using as an access point then decided to move it to main router function so I did a reset. I don't know if its related but now I have no ethernet connection(no o...
jmacchi
I fully reset it, my phone is saying that network has no internet access. Now it's connected in ap mode after my old netgear router. connecting from the wax202 lan to pc kills the otherwise working lan connection from the old netgear. it seems like the wan port on the wax202 is dead, troubleshootiing no light in the manual didn't help. appreciate the help btw
