kc1881
Mar 19, 2024Aspirant
WAX204 intermittently disconnects from the internet
Hello, I have an WiFi 6 AX1800 Dual Band Wireless Access Point Model WAX204 that is connect to my main router. I use the WAX204 as an access point in the office at the back of the garden. Connectio...
- Mar 26, 2024
Operating this WAX204 in AP or in Router mode? As you are hiding the IP address with a xxx it leaves the impression it's a public IP address, as obtained from e.g. from a cable router (where the ISPs allow or offer more than one address):
[Internet connected] IP address: xxx, ...
In case it's a private RFC1918 IP address, it could be connectivity issue to your router LAN, or some odd power saving on the PHY LAN link....
schumaku
Mar 26, 2024Guru - Experienced User
