SuzyQ77's avatar
SuzyQ77
Intermittent Internet DoS attacks (RST & Fraggle)
I have a Nighthawk RAX50v2 router that I set up maybe 3 or 4 months ago.  Due to a neighbor having fiber installed 2 doors down, my cable line with Spectrum was completely cut in mid-June.  The cable was replaced, but about a week later, I started experiencing very brief outages (1-2 min.) at very random times with both my WiFi and hardwire Ethernet connection to my computer.
I spoke with Spectrum and was told to investigate with Netgear, and if that fails, to get a new modem from Spectrum.  They claimed they could see no outages on their end, but it wasn't foolproof.
When I saw the Netgear logs, I was surprised to see all sorts of DoS attacks including snmpQueryDrop, Fraggle attack, ACK Scan, RST Scan, etc.
Many of the Fraggle attacks are from the same source, but sometimes it says "unknown."
I am NOT a technical person when it comes to routers, so all these terms are as clear as mud to me.  Not sure how concerned I should be (aside from the annoyance of intermittent Internet).
I do have Proton VPN which I had shut off due to some conflicts with things, but I turned it back a short while ago - so far my Internet has been more stable, but that doesn't help things with my WiFi situation (watching streaming shows - things drop out sometimes every 10 min. or so).
Would welcome anyone's advice.  Thanks in advance!  (Interestingly one of the Fraggle attacks took place when my Proton VPN was turned on, but I have stayed online this entire time - maybe that is the answer at least for my computer but I'm guessing wouldn't help with the WiFi.)
  • Those tend to be false positives and nothing to worry about. You can go into the logs and disable the logging of them if they bother you.
    If you're having wired drops, it tends to not be the router and more likely the line. the problem with spectrum is they locked down their modems so you can't check the logs/line connections on the modems anymore. Easy check? Take the router out of the loop for a period. Just directly connect a pc to the modem and use it. See if it drops or stays stable. Its not definitive if it happens rarely but if its happening, they can't blame the router.
  • plemans's avatar
  • Thank you - I looked up the IP addresses and realized all the fraggle attacks were Spectrum-related.  I'll give your suggestion a try.  Thanks again!
