kc1881
Mar 19, 2024Aspirant
WAX204 intermittently disconnects from the internet
Hello, I have an WiFi 6 AX1800 Dual Band Wireless Access Point Model WAX204 that is connect to my main router. I use the WAX204 as an access point in the office at the back of the garden. Connectio...
- Mar 26, 2024
Operating this WAX204 in AP or in Router mode? As you are hiding the IP address with a xxx it leaves the impression it's a public IP address, as obtained from e.g. from a cable router (where the ISPs allow or offer more than one address):
[Internet connected] IP address: xxx, ...
In case it's a private RFC1918 IP address, it could be connectivity issue to your router LAN, or some odd power saving on the PHY LAN link....
schumaku
Mar 26, 2024Guru - Experienced User
kc1881
Apr 02, 2024Aspirant
Thanks for the reply and apologies for the late update. The WAX204 is setup as an AP. However, did not think of looking at my Vriginmedia router until you mentioned it because connectivity, wired/wireless on my Virginmedia router was working fine when the AP was experiencing issues.
I ran a diagnostic check on the VM router which cambe back clean, but the diagnostic check restarts the VM router. Since then, the AP has not had an issue, no amber light and no connection drops.
Thanks for your help.
