TeamForge
Dec 14, 2021Follower
WAX204 LAN ports not working
Hi community, I use a WiFi 6 AX1800 Dual band wireless access point WAX 204 (I'll refer to it as WAX 204 from now one) for my small business wifi. The wifi itselfs works like a charm. No issues t...
Dec 14, 2021Guru - Experienced User
If you're running the WAX and the fritzbox in router mode, it causes a double nat. some devices play nicely with double nat's but not all.
Try going into your fritzbox and putting the WAX's IP address into the fritzbox's DMZ.
https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-7590/131_Setting-up-a-DMZ-with-the-FRITZ-Box/
