hytech
May 26, 2022Follower
WAX214 dropping clients in a roaming environment
So I have 5 WAX214's configured with the same SSID with roaming enabled (only usable with WPA2); they have static IP's assigned to them (on a pfsense firewall appliance), some have been connected to ...
ihavealegohead
May 27, 2022Guide
I have a similair setup with pfsense and three WAX214's -- check the log file for "IEEE 802.11: disassociated" -- if so check if my solution works :
