Hash_Slinging_S
Sep 03, 2022Tutor
WAX214 user.emerg : uci: Entry not found and speed issues
Was trying to figure out why this WifI6 AP is not providing anything more than 300MB connections I looked at my logs on my and saw this entry. Not sure what this is for or what to do with this. If an...
- Sep 04, 2022
Are you asking why you don't get Gigabit? Have you talked to your Internet service provider?
Device:
- WAX214 - AX1800 WiFi 6 Dual Band PoE Wireless Access Point
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. The WAX214 is an AX1800 PoE Access Point in Netgear's "business" range.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
schumaku
Sep 05, 2022Guru - Experienced User
Hash_Slinging_S
Sep 07, 2022Tutor
Thanks for the reply, will be reading the material.
