richford
May 03, 2022Tutor
WAX214 wifi second unit without ethernet
I want to connect two WAX214's to get full coverage aroundthe house. One of them I can connect via ethernet to the router - which is a BT Smarthub 2. But the second one will be in an area of the...
May 03, 2022Guru - Experienced User
No.
the WAX214 doesn't have wifi repeating.
Its needs to be hardwired in.
- richfordMay 03, 2022Tutor
Thanks for the swift reply!! That takes care of that then.
Will the WAX610 do this then (or rather a pair of them)?
- plemansMay 03, 2022Guru - Experienced User
If you're wanting a mix of wired and wireless access points, I'd be looking at the orbi line. There's always the pro line if you're wanting a business setup.
