richford
May 03, 2022Tutor
WAX214 wifi second unit without ethernet
I want to connect two WAX214's to get full coverage aroundthe house. One of them I can connect via ethernet to the router - which is a BT Smarthub 2. But the second one will be in an area of the...
May 03, 2022Guru - Experienced User
No.
the WAX214 doesn't have wifi repeating.
Its needs to be hardwired in.
richford
May 03, 2022Tutor
Thanks for the swift reply!! That takes care of that then.
Will the WAX610 do this then (or rather a pair of them)?
- plemansMay 03, 2022Guru - Experienced User
If you're wanting a mix of wired and wireless access points, I'd be looking at the orbi line. There's always the pro line if you're wanting a business setup.
