paulgad
Mar 28, 2025Aspirant
WAX214v2 use POE instead of POE+ redux
Have the same issue as prosyn in his post "WAX214v2 use POE instead of POE+"
Need to know what the resolution to this situation is.
Switch is Cisco WS-3650 running Cisco IOS XE Software, Version 16.12.13
When running an older IOS version LLDP was not seeing any information and the device was being seen as a type 4 and allocated 30 W.
Still have the error PoE/AF Input power detected. Use POE+ or AT Switch or Power Adapter to power the AP.
Have tried different cables and ports with the same results.
Need to understand if this is affecting the AP performance or is just cosmetic and how to resolve this.
AP firmware is Firmware Version: V1.0.2.5
MC-Cisco-Stack#show power inline gigabitEthernet 2/0/3 detail
Interface: Gi2/0/3
Inline Power Mode: auto
Operational status: on
Device Detected: yes
Device Type: Ieee PD
IEEE Class: 4
Discovery mechanism used/configured: Ieee and Cisco
Police: off
Power Allocated
Admin Value: 30.0
Power drawn from the source: 30.0
Power available to the device: 30.0
Actual consumption
Measured at the port: 5.0
Maximum Power drawn by the device since powered on: 8.3
Absent Counter: 0
Over Current Counter: 0
Short Current Counter: 0
Invalid Signature Counter: 0
Power Denied Counter: 0
Power Negotiation Used: IEEE 802.3at LLDP
LLDP Power Negotiation --Sent to PD-- --Rcvd from PD--
Power Type: Type 2 PSE Type 2 PD
Power Source: Primary PSE
Power Priority: low low
Requested Power(W): 25.5 25.5
Allocated Power(W): 25.5 25.5
Four-Pair PoE Supported: No
Spare Pair Power Enabled: No
Four-Pair PD Architecture: N/A
MC-Cisco-Stack#show lldp neighbors
Capability codes:
(R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
(W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID Local Intf Hold-time Capability Port ID
MsG_WiFi-upper-barn Gi2/0/11 80 W eth0
802a.a860.81c5 Gi1/0/4 240 eth0
cc96.e5ac.d69e Gi2/0/2 3601 cc96.e5ac.d69e
MC-Cisco-Stack.masteGi1/0/6 120 B Gi0/0
Total entries displayed: 4
Thank you
- paulgadAspirant
It seems to run ok, and is getting powered, just worry that it might have issues if it thinks it's underpowered.
Was hoping that one of the employees let me know what to check to make sure it's actually ok with the power supplied.
Will see if they get back to me.
PG
Not a Netgear rep here, however I try to answer anyway; When operating a WAX214v2 on 802.11af, the WebUI does indeed report this fancy "PoE/AF Input power detected. Use POE+ or AT Switch or Power Adapter to power the AP." Don't see any power conserving settings in place, the 5 GHz radio does continue to operate on up to 80 MHz bandwidth, the WiFi clients still sync and operate on 1201 Mbps at 5 GHz (that would be the case on bigger WAX2xx/6xx or WBE7xx where 160 and 320 MHz bandwidth would be put in place). I guess that "check" is in place from the WAX218 model, so suspect a "false positive" indication..
Looking from a different perspective, 802.11af does offer up to 15,4W at the PD (powered device). This is well within the power draw of the WAX214v2 of 15.1W, as shown in the tech data on the data sheet and/or the user manuals. Therefore, there is no reason to lower the power.
-Kurt.
