ademrudin
Apr 25, 2021Tutor
WAX218 crashes when lenovo laptops connect
I have a brand new WAX218 access point. The access point immediately crashes (and then slowly reboots) when I try to connect my main personal laptop - a Lenovo X1 Extreme Gen3 with the Intel AX201...
May 04, 2021Guru - Experienced User
Glad you got it functioning!
Sad that something in the POE isn't working properly.
schumaku is correct, it could be several things that could be causing the issue with the POE
RaghuHR
Jun 01, 2021NETGEAR Expert
Please use the latest FW.
Important Bug Fixes:
- Fixes the issue where the AP sometimes reboots with certain connected WiFi clients.
- Fixes the schedule reboot issue.
- Fixes inability to read the connected client list via SNMP.
https://kb.netgear.com/000063707/WAX218-Firmware-Version-1-0-3-3
