gregz83
Feb 23, 2021Follower
WAX218 Power Adapter
With regards to the power adapter, can someone tell me what the exact physical specifications are of the barrel connector?
Netgear Support, please dont bother linking existing documentation, they barrel size (inner and outer diameter, and length) are not listed in your current documentation.
https://www.netgear.com/business/wifi/access-points/wax218pa/
https://www.netgear.be/business/products/wireless/accessories/PAV12V.aspx
Its a 2.1mm inner diameter and 5.5mm outer diameter plug size.
gregz83 wrote:Netgear Support, please dont bother linking existing documentation, they barrel size (inner and outer diameter, and length) are not listed in your current documentation.
For support, warranty, regulatory and legal reasons it is perfectly sufficient if Netgear is providing just the power supply designation like PAV12V, for Europe it's the PAV12V-100EUS SKU.
If a customer is wrecking his access point or whatever device by using wrong specs, like 24V DC, whatever AC voltage, ... or the house is burning down it's off the vendor's control and resposibility.
