Retired_Member
May 21, 2023WAX220 Guest Network - Unsecured
Do not buy this Access Point and expect a secure Guest Network. The original firmware had an option for L2 Isolation, but updating removes this option and reverting does not restore it. The Guest N...
- Retired_MemberJun 08, 2023
schumaku wrote:
Retired_Member wrote:Who knows what else is not working as intended...
Whatever impression you want to bring up with such shabby comments and poorly formulated subject lines. just poor sportsmanship or bad intentions?
Unexperienced users (some >99% of the readers in such a user community) tend to understand "WAX220 Guest Network - Unsecured" very different. Wouldn't "WAX220 Can't enable Client Isolation to Block LAN Subnet Access" describe the effective information much better? Just my 2 Cents.
Reminder: We talk about essential wireless AP products WAX214v2 (street price less than 88 USD ex VAT!) for a WiFi 6 AX1800 Dual-band PoE Wireless Access Point, and WAX220 (street price less than 129 USD ex VAT) for an AX4200 Dual Band AP with a 2.5 GbE network connection.
You really love those partial sentences, don't you? I didn't know this was a competition, Mr. Good-sport.
Unexperienced users absolutely need to be made aware of a product that has flaws. Quit defending a company you say you claim to not be affiliated with. You're playing a semantics game because you have a must-be-correct complex at this point.
You still haven't tested the WAX220 as thoroughly as I have, and you just glazed over some basic stuff, like an NPC help desk rep.
Here's a real reminder: I just picked up a different brand, and return all the Netgear products I bought. The competitor was even priced almost identically for each product (switch and access point), and they offer A LOT more control, along with functionality that isn't broken.
The solution? Buy something else, don't waste your cash till Netgear decides that firmware is important, again.
Done with this thread, the replies coming in are from sources out of their depth.
schumaku
May 23, 2023Guru - Experienced User
i was almost set confirming your (hard to believe) information, as i like to take challenges. Indeed, for a moment it appeared to me the web UI controls for Ordered factory new WAX220 and WAX214v2 and took the the plunge.
The original firmware had an option for L2 Isolation, but updating removes this option and reverting does not restore it. The Guest Network is broken, since it allows access to any device connected to the internal network via Ethernet with no way of isolating.
This all tastes to me like an odd problem
It is a bad joke that even the WAX214 has better security and allows for L2 Isolation on both guest and regular SSID's.
As I believe in good stories, and don't like bad jokes except from those I'm coding myself, please allow me to post some screenshots taken these minutes.
WAX220, v1.0.3.0
WAX214v2, v1.0.2.2
In no way, I don't want to insist there is no issue or problem. Can't get it out of my head, believe having seen the very same Web UI (e.g. on current Chrome or Edge) with the two lines missing or hidden. Afraid, have not spotted any obvious cause.
For my part, I don't like the (i) text ... it's not clear enough to me at least. That's why I included it on the screenshot above.
- Retired_MemberMay 24, 2023
schumaku wrote:
Retired_Member wrote:Do not buy this Access Point and expect a secure Guest Network.
Thank you, that confirms my suspicions of the WAX214v2's firmware, but I should have said I tried out the WAX214v1, which has noticeably different firmware. The L2 Isolation is present there and the Guest Network does not allow clients to access the LAN.
