railbird
Jul 03, 2021Follower
WAX241 / AX1800 - Connectivity drops with certain configurations
Hi everybody - bit of a complicated setup so I'll try to keep this as concise as I can. Using the WAX214 wifi router with 3 SSIDs: SSID 1 - Not tagged traffic / default VLAN. Using mixed mode W...
DaneA
Jul 08, 2021NETGEAR Employee Retired
Welcome to the community! :)
As far as I have checked, there is no issue on the WAX214 pertaining specifically to what you have described on your initial post. Have you tried to perform a factory reset on your WAX214? If not yet, kindly try it then reconfigure the settings from scratch and check if the same problem will occur.
DaneA
NETGEAR Community Team
