railbird
Jul 03, 2021Follower
WAX241 / AX1800 - Connectivity drops with certain configurations
Hi everybody - bit of a complicated setup so I'll try to keep this as concise as I can. Using the WAX214 wifi router with 3 SSIDs: SSID 1 - Not tagged traffic / default VLAN. Using mixed mode W...
dumbo25
Nov 24, 2021Tutor
I had a similar issue with WAX214/AX1800. I could not get the 2.4GHz radio to broadcast its SSID on firmware version 2.0.1.3. I had to set the 2.4GHz to a specific channel, and to 20MHz bandwidth.
Follow-up question. Is there anyway to dosably 802.11b and 802.11g? I want my 2.4GHz radio/SSID to support 802.11n-only.
