kazh
May 29, 2026Aspirant
WAX610 – 802.1X Supplicant on Wired Uplink Port – Feature Availability
Hello NETGEAR Support Team,
I am currently deploying a network infrastructure using several WAX610/WAX620 access points (firmware up to date) combined with a MS510TXPP managed switch.
As part of my security architecture, I would like to enable 802.1X port authentication on the switch ports connected to the access points, in order to prevent unauthorized access in the event an AP is physically removed and replaced by a rogue device.
This requires the WAX610 to act as an 802.1X supplicant on its wired uplink/LAN port — independently from the 802.1X authenticator role it already plays for wireless clients via RADIUS.
After reviewing the WAX610 user manual thoroughly, I could not find any mention of this capability on the wired port.
My questions are:
- Does the WAX610 currently support 802.1X supplicant functionality on its wired uplink port?
- If not, is this feature on the roadmap for a future firmware release?
This is a fairly standard enterprise security requirement, and I believe many customers deploying WAX610 in environments where physical security of the AP cannot be fully guaranteed would benefit from it.
Thank you for your time and assistance.
Best regards
1 Reply
Hello kazh ,
Nice to meet you here. However, this is a community - mainly kept alive by volunteers - and not a formal support channel.
As a long term Beta tester, active users of a large number of NTGR switches and APs, and active community member, I'm afraid, and tend to say no. Never seen it at least in the Web UI and the fine documentation for now.
Excellent idea. Aware this exists on the much more expensive APs from some competitors.
As a long term Beta tester and active community member, I'm afraid, and tend to say no.
Netgear does not publish roadmaps and further intentions.
Keep in mind, adding such a feature does span wide, some API definitions for Netgear Insight and Netgear Engage need to be implemented, too. And of course, much more APs like the current WBE7xx, as well as future APs need a bigger feature set.
Further on, both the WAX610/WAX620 are relative old models. As such, the request for these (and several newer WAX6xx) might be very optimistic. You can try your luck anyway -> Feature Requests | NETGEAR Communities
-Kurt
