arainer
Jul 21, 2021Aspirant
WAX610 ceiling mount incompatibility and advice
Hello,
I got pre-installed AP drops in my new house. I bought some NETGEAR WAX610 APs and I’m trying to mount them, but it seems like i don’t have a compatible fit. The holes are just 1/8” too far apart to slide on properly using the default holes. Using the mounting brackets is to no avail because no T-bar and the screw holes are way too close (unless I’m doing in wrong). What should i do? Is there some bracket converter I can buy?
Images: https://imgur.com/a/f39DaeH
Thank you!
- schumakuGuru - Experienced UserAdd an additional hole into the AP mounting plate, or extend one or both mount hopes by about 1.5 mm each.
- arainerAspirant
Hi, not sure if it is noticable in my photos, but the celling is a wide drop and the AP mounting plate is very small--smaller than the AP's mount holes. Maybe I can fashion a thin piece of wood and put holes in it? I worry about the heat though so not sure if that is the best approach.
There is also a mounting plate supplied with the WAX 610 - I would make these two holes "fit" to this plate, and clip the WAX on it.
