redders123
Aug 05, 2021Tutor
WAX610 extenders not connecting
Hi there - 3 x WAX610s have worked faultlessly since Nov 20, but in the past few days, despite no changes to the network, we've seen these devices disconnecting at random times. My plan was to factor...
redders123
Aug 07, 2021Tutor
Raghu davys Thanks for your help - the bizarre solution (as suggested by @davys) was to change the secondary DNS settings on the root device from the gateway (192.168.1.1) to 8.8.8.8. Once I'd done this I perfomed another reset on the WAX610 extenders then claimed them through the insight cloud interface - both extenders then connected and appear to be working fine.
- schumakuAug 07, 2021Guru - Experienced User
The gateway DNS does refer to the ISP supplied DNS IPs typically, comes in along with the public IP by DHCP. Some trends with the ISP seem to provide safe DNS only - what could be nice as long as using a Web browser, but painful on IoT as it does just happen in the dark....
- RaghuHRAug 19, 2021NETGEAR Expert
Hi redders123
Could you please let us know if you can try our beta firmware which is having the potential fix?
Thanks,
Raghu
- redders123Aug 19, 2021TutorHi there, sure, I’m happy to try it but my insight subscription expires tomorrow. Will that be an issue?
Best
