gautamdas
Mar 26, 2021Aspirant
WAX610 firmware 9.3.0.6 issues
After upgrading to 9.3.0.6 lost WDS connection and after some troubleshooting discovered country setting United States was gone. Had to roll back to 9.2.0.7 and factory reset before I could get WDS ...
- Mar 26, 2021
Hi gautamdas
Could you please let us know your WAX610 SKU details? Are you using WAX610-100EUS?
Please refer the release notes:
https://kb.netgear.com/000062983/WAX610-WAX610Y-Firmware-Version-9-3-0-6
- Removed Albania, North Macedonia, Kazakhstan, Monaco, Russia, Ukraine, United States, and Japan from the country/region menu for the European SKU.
gautamdas
Previous attempt inserting an image failed. Adding an attachment.
schumaku
Mar 26, 2021Guru - Experienced User
The SKU is printed on the device label only.
An indication could give the Country/Region list selection available (unless it's Insight managed) on Management -> System -> Basic -> General.
- gautamdasMar 26, 2021Aspirant
Country/ Region = United States
See attached screenshot.
- schumakuMar 26, 2021Guru - Experienced UserThe question was related to the other selection options - that one was visible before
Checked device label on the back of the unit.
It says WAX610 EU.
Guess I was offered an European unit for beta testing even though I live in Florida, USA.
That explains everything.
Thanks.
