texmex1978
Sep 28, 2022Aspirant
WAX610 Firmware update failed
Hello Netgear WAX610 Firmware: V9.6.0.7 I tried via insight app to upgrade the firmware to 10.2.0.16. This upgrade started automatically after initially setting up the device. The upgrade...
amaradevid
Feb 03, 2023Star
Try these steps to resolve the issue 👇:
- Make sure that your devices connected to a fast internet connection.
- Turn off the device and unplug it from the power source for a few minutes. Then, plug it back in and turn it on.
- Go to the netgear website and download the latest firmware for your device.
- Folow the instruction provided by netgear to update firmware manually using the downloaded file.
If these steps don not resolve the issue, you may need to contact Netgear Support for further assistance.
