thecodemonk's avatar
thecodemonk
WAX610 no DHCP unless rebooted every few days
I have two WAX610s connected to a GC108P. The switch is then connected to a OpnSense router. Every couple days, clients on the wifi network cannot get a DHCP address. I have to reboot the WAX610 they are connected to in order for it to start working again. The first time it happened, I did a packet capture on the AP and it was receiving the DHCP requests, but it seems like it may not have been forwarding them onto the OpnSense router.
Is this a known issue that is being worked on? If not, what do you need to troubleshoot this issue? Since I can reboot the AP and all is well, it seems like this may be an issue with the AP and not the switch or router, but I am open to steps to figure that out.
Thanks!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    thecodemonk,
    Welcome to our community! :)
    It seems that you are having issues with your access point. May I know the firmware version? I believe there was a fix regarding this where the DHCP broadcasts are dropped by the AP when broadcast/multicast rate limit is enabled.
    Please update the firmware to its latest version and please read the release notes before upgrading the firmware.
    John
    NETGEAR Community Team
    • thecodemonk's avatar
      thecodemonk
      I am already on 9.3.0.6 and it was installed on March 30, 2021. I've had the problem since then.
      I submitted a ticket with netgear support and am currently waiting on additional help from them. I'm open to other suggestions to try though. The problem hasn't happened in a couple days so it's about due to happen any day now.
      • JohnC_V's avatar
        JohnC_V
        thecodemonk,
        Thanks for letting us know. Please give us an update too on the progress so that our community will benefit from it too.
        John
ProSupport for Business
