Styks
Oct 21, 2023Aspirant
WAX610 not staying connected
I have an Orbi Pro router connected to a Netgear GS108LP unmanaged PoE switch connected to a WAX610 WAP. The WAP regularly loses connection. It will go on and offline randomly and often won’t even ...
Oct 22, 2023Guru - Experienced User
2 things you could try to troubleshoot.
1. try powering the WAX610 off its own power supply (for testing). the supply is quite common and you might have one from a different device sitting around. (2.5a, 12v) if that stays stable then you're good. if not....
2. then directly wired it to the Orbi pro with the wax610 on its own power supply.
Just trying to eliminate the switch and its poe capability to narrow the issue
Styks
Oct 22, 2023Aspirant
Could it be that the WAX610 can’t be supported by an unmanaged switch?
