-BAM-'s avatar
-BAM-
WAX610 RADIUS - Need separate Authentication & Accounting Servers
Hi,
The WAX610 AP does not allow different RADIUS servers to be defined for authentication and accounting functions.  This is very disappointing given that this is a business product.
The scenario is that we need to authenticate to our main user directory but have accounting performed by the firewall to permit network access.  This works fine with our older TP-Link EAP225 AP which allows a separate server to be defined for each RADIUS function.
I noticed that on the original release firmware that the UI had separate server fields to define the auth & accounting functions but it would throw an error if I tried to set different servers, which made me think it might just be available in a later firmware.  However the latest firmware has removed the separate accounting fields completely and there is now only a switch to enable or disable accounting information to be sent to the single RADIUS server.
As a business product, being able to send accounting information to a separate device would be a common feature and I am very surprised that this is not currently possible on the WAX610 as this renders the product not fit for purpose for our intended use case.
Will an update be available to resolve this in the near future?
Best regards,
Bam
    • BasuKhodanapur's avatar
      BasuKhodanapur
      Apprentice
      Hi -BAM- ,
      There will not be a separate accounting server config field now.
      Initially we had separate radius server field for authentication and accounting, later we received some enhancement to have it common, so we removed the accounting IP filed, currently the authentication IP will be applied to accounting as well.
      There is a switch to enable accounting server.
      Thanks,
      Basavaraj
      • -BAM-'s avatar
        -BAM-
        Hi,
        thanks very much for the response.
        Very dissapointing that this option will not be avaialble as it renders the product unable to be integrated into our environment due to such limitation.
        Will return this product and go for TP-Link in future.
        Thanks again and best regards.
ProSupport for Business
