astralblue
Jun 29, 2021Aspirant
WAX610 V9.5.1.20 – WAX6XX SNMP MIB inaccessible, walk skips the enterprises tree
Greetings, I have upgraded my 3 WAX610 APs to V9.5.1.20 today, and as the release notes say, the SNMP function with non-default community strings has been restored, but partially: It seems that the ...
schumaku
Jul 01, 2021Guru - Experienced User
Can't get access to the NTGR private MIB on the WAX610 or 620 (no 630 to test) V9.5.1.20, too. Suspect bug. RaghuHR please.
- RaghuHRJul 01, 2021NETGEAR Expert
- schumakuJul 01, 2021Guru - Experienced User
RaghuHR wrote:
Currently enterprise MIBs are not supported.
This is a little bit odd, consideing explicitly these private MIB are made available along with the current firmware releases for the WAX610/610Y/620 and the WAX630...
-- Specification. -- -- Status: Release -- Version: 9.0 -- Internal Source Code Version:9.0.0.46 -- Date: 1 Aug 2020 -- History : -- 1.0 : Initial Version -- 9.0 : Updated to MIBs to show once are deprecated.Deprecated mibs will be obeslete in next release. -- ******************************************************************** WAX6XX DEFINITIONS ::= BEGIN IMPORTS OBJECT-GROUP FROM SNMPv2-CONF enterprises, IpAddress,Unsigned32, OBJECT-TYPE, MODULE-IDENTITY, Counter32, Counter64, NOTIFICATION-TYPE, TimeTicks FROM SNMPv2-SMI DisplayString, RowStatus, TruthValue, MacAddress FROM SNMPv2-TC; -- ******************************************************************** -- * MODULE IDENTITY -- ******************************************************************** wax6xx MODULE-IDENTITY LAST-UPDATED "202008010000Z" -- 01 08, 2020 at 12:00 GMT ORGANIZATION "NETGEAR Inc." CONTACT-INFO "350 East Pumeria Drive San Jose, California 95134 Phone: (408) 907-8000 Fax: (408) 907-8097 Web Site: http://www.netgear.com" DESCRIPTION "The MIB module for 802.11a/b/g/n/ac Enterprise WiFi AP. iso(1).org(3).dod(6).internet(1).private(4). enterprises(1).netgear(4526).productID(100).accesspoint(7).wax6xx(14)" ::= { accesspoint 14 } -- -- Node definitions -- -- The Enterprises Number -- 1.3.6.1.4.1.4526 netgear OBJECT IDENTIFIER ::= { enterprises 4526 } -- 1.3.6.1.4.1.4526.100 productID OBJECT IDENTIFIER ::= { netgear 100 } -- 1.3.6.1.4.1.4526.100.7 accesspoint OBJECT IDENTIFIER ::= { productID 7 } -- Wireless LAN Access Point ...... - astralblueJul 01, 2021Aspirant
RaghuHR, thank you for the update. When can we expect the MIB to start working?
