hector1990
Oct 14, 2015Aspirant
NightHawk R7000 Router page inaccessible
Hi,
This is a brand new router outta the box! & am not able to login or access the Router's pageon my Desktop! My Default gateway (ipconfig) is 192.168.1.1!
steps that I treid
1.) 192.168.1.1 , 10.0.0.1, routerlogin.net all three are inaccessible!
2.) the router connects fine via wireless, I can access the login page from my phone with 192.168.1.1!
3.) I can access it from my Laptop Wired/WIreless! 192.168.1.1!
4.) Hard reset .... nothing helped.
5.) to isolate the issue, I tried with different cables & another router & they just connect fine.
Help appreciated :)
Thanks
try adding routerlogin.net and Gateway IP in trusted zone or sites. So it will never block going forward.
By way did you tried on the new beta firmware , its fast and has few improved features
- netwrksMaster
You can't login on to the router? Have you tried to connect to the default SSID and passphrase provided with the router? If you do an ipconfig /all does your laptop or desktop get an IP Address from the router when connecting with an ethernet cable??
The other router is disconnected?
Have you tried clearing your browser's cache?
Have you tried another ethernet port?
- storm1985Prodigy
Try disabling any firewall on your Desktop.
If you can access the router on your phone and laptop then definitely not a router issue.
- hector1990Aspirant
Hi, Uninstallating the AnitVirus worekd(Kaspersky Internet Security 2015), now am able to access the router page!
any work around for this?Thank you very much :)
- mondenathProdigy
