bcre3306
Dec 28, 2023Aspirant
WAX610 won't connect via 802.3AT
I have 3 WAX610's around my house and they are all powered via POE+ but all of the units are only pulling about 9W which is causing them to all flag issues saying they are running on 802.3af. The sw...
- Mar 11, 2024
My issue ended up being the switch didn't support it. Sorry probably not much help for you but figured I would let you know
bcre3306
Dec 29, 2023Aspirant
I'm using a cheap Steamemo 5 port gig 52W POE switch from amazon(see link below). I'm guessing you're right with the handshake issue as all three are only operating at around 8W per AP. There is no setting for LLDP as the switch is extremely basic. Any suggestions would be greatly appreciated.
https://www.amazon.com/dp/B0BQ6MP1HT?ref=ppx_yo2ov_dt_b_product_details&th=1
Thank you
Pramendra
Jan 02, 2024NETGEAR Expert
Hi,
I hope you are running the latest firmwares on the AP. If not then please try upgrading to the latest available firmware.
Thanks!
Pramendra
- bcre3306Jan 02, 2024Aspirant
Hi
Yes, I'm running 10.7.5.3 on all 3 units.
- capellmanrjMar 11, 2024TutorI’m having the same issue with numerous switches, including Netgear connected to WAX610
- bcre3306Mar 11, 2024Aspirant
