bcre3306
Dec 28, 2023Aspirant
WAX610 won't connect via 802.3AT
I have 3 WAX610's around my house and they are all powered via POE+ but all of the units are only pulling about 9W which is causing them to all flag issues saying they are running on 802.3af. The sw...
- Mar 11, 2024
My issue ended up being the switch didn't support it. Sorry probably not much help for you but figured I would let you know
ReneD
Mar 25, 2024NETGEAR Moderator
Hello bcre3306,
The Access Points are just feeding the power from the POE switch. It will be nice to share the make/model of the switch and the cable used and its length to investigate the issue. This issue is more likely on the switch.
Have a lovely day,
Rene D
Netgear Team
- capellmanrjMar 25, 2024Tutor
I wish that this were the case. All of my switches are Netgear. When the problem started, I replaced the switches and the result was the same. I then swapped the router to my original and everything worked fine. I then hooked up my original switches and the old router still worked fine. I then hooked up the new router again and the connections would not work. This is when I realized that it was the new router.
- schumakuMar 25, 2024Guru - Experienced User
Ok, so and?
bcre3306 wrote:
I'm guessing you're right with the handshake issue as all three are only operating at around 8W per AP.
This does tell me your WAX610 are operating on 802.3af only, and are active in some power-saving low-power mode.
A fully active WAX610 does draw up to 15.3 W, a WAX610Y up to 16.1 W - so this is about the PoE power the AP should request, and requiring 802.3at. On the Netgear WAX, they can bring the Wi-Fi radio(s) to just 1x1, from the full 2x2 or 4x4 modes on the fly, and back to full speed if more throughput is demanded. Not much to gain on just a 802.3af PoE PSE, not much fun when it comes to the Wi-Fi performance. Netgear does support this as part of the Energy Efficiency Mode, which can be controlled from Insight Premium and Insight Pro as a power-saving mode - if not a lot of demand is on the Wi-Fi.
For some reasons, sometimes, experienced users are asking about exact models, firmware versions, ....
No idea what impact a different router should have on the switches and the PoE.... Please send crystal ball.
