bcre3306
Dec 28, 2023Aspirant
WAX610 won't connect via 802.3AT
I have 3 WAX610's around my house and they are all powered via POE+ but all of the units are only pulling about 9W which is causing them to all flag issues saying they are running on 802.3af. The sw...
- Mar 11, 2024
My issue ended up being the switch didn't support it. Sorry probably not much help for you but figured I would let you know
ReneD
Mar 25, 2024NETGEAR Moderator
Hello bcre3306,
The Access Points are just feeding the power from the POE switch. It will be nice to share the make/model of the switch and the cable used and its length to investigate the issue. This issue is more likely on the switch.
Have a lovely day,
Rene D
Netgear Team
capellmanrj
Mar 25, 2024Tutor
I wish that this were the case. All of my switches are Netgear. When the problem started, I replaced the switches and the result was the same. I then swapped the router to my original and everything worked fine. I then hooked up my original switches and the old router still worked fine. I then hooked up the new router again and the connections would not work. This is when I realized that it was the new router.
