Johnweyers
Dec 13, 2022Follower
WAX610Y being installed in my barn
I need help picking a PoE+ injector or switch for my WAX610Y access point. The access point is located in a barn that has livestock so i am needing a switch or injector that can be used in harsh environment. I have power to the barn so i can plug the injector into a power socket. I have already mounted the WAx610Y and have run outside Cat6a Ethernet to where my poE+ will be located. I need something reliable but not cost prohibitive.
1 Reply
I would have thought that this might be best thrown at PoE experts, but if it is something for people with this model, then this may not be the best place to seek help.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
