david_farmer
Sep 04, 2026Aspirant
WAX615 – Random reboot after ~72h uptime, matches known bug on latest firmware
Product: Netgear WAX615 Firmware version: V12.8.0.6 Summary: My WAX615 reboots unpredictably, roughly every ~71.9 hours of uptime (not a fixed wall-clock time), even with the scheduled reboot feat...
david_farmer
Sep 05, 2026Aspirant
And just like that, as soon as I post a thread in here I get a random reboot that doesn't fit the pattern. It appears to be a consistent time around 6:45am.
Sep 06, 2026Guru - Experienced User
Has a factory reset been performed since last update?
How is the AP configured? Dynamic or Static IP address for the WAX?
What channels are you using on it?
Brand and model# of host router the AP is connected too?
MIght revert to prior working FW on the WAX.
You'll need to make contact with NG support regarding this if this can't be resolved here in the forums.
- david_farmerSep 07, 2026Aspirant
Hi,
I have performed a factory reset on the device.
I configure it with a static IP.
I'm using both 2.4GHz and 5GHz channels. (I've tried restricting to one or the other, with no difference in behaviour)
The router is an Ubiquiti Edgerouter X
Unfortunately even with older firmware I was experiencing the same behaviour. It has been occurring since purchase.- FURRYe38Sep 08, 2026Guru - Experienced User
Seems like if this is happening with with older FW, possible this unit is faulty and needs replacing.
Might as NG support if they have any RMA options available to you.
- schumakuSep 08, 2026Guru - Experienced User
Reads like this problem is specific to your WAX615 unit.
In most markets, Netgear does offer a five years warranty (few conditions apply, like the original customer).
The WAX615 was introduced in spring 2022, so all are well within the standard warranty terms.
Head to HTTPS://my.netgear.com/ , select your WAX615 serial number and contact Netgear by following the [Request Hardware Support] process.
[the screenshot should appear here, but I get just the "Upload failed" error message again JulienR ]
Even my oldest (early) WAX615 have almost one year of warranty time left.
- Sep 02, 2018Retired_Member
