tbozo's avatar
tbozo
WAX620 Dead loop on virtual device
I switch from my WAX610 to my WAX620 which was not used as I tried to fix the error that I'm seeing in the logs.
Unfortunately I have the same message in the WAX 620 logs
In the file diagnostic I see
Kernel Logs
NETGEAR5D1DDF#dmesg
[ 120.456200] write_to_alm_fifo: Not enough free space to write alarm
[ 128.771738] Dead loop on virtual device wifi1vap0, fix it urgently!
I don't know how to investigate more.
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello tbozo
    And welcome to the NETGEAR Community! 🙂
    I just have some few things to ask first. Does it also appear even if the device has been factory defaulted? Do you have the latest firmware on your access points? Do you notice any issues aside from seeing errors on logs? Would you mind sharing the whole logs?
    Have a lovely day,
    Erwin
    Netgear Team
    • tbozo's avatar
      tbozo
      My WAX 610 was up to date and was having the problem.
      I switched it to a never used WAX 620 so factory reseted, but not updated yet.
      I started to investigate on my WAX 610 because I had some issues with ACL that seems not to be recognized, I also have a Sonos setup (known to have a STP problems) which I thought might create a loop, but I've disconneted the wired speakers to be sure it wasn't that.
      About sharing logs I downloaded the diagnostics so I have the tar.gz but is it safe to publicly post it ? I guess it contains some sensitive data, no ?
      • schumaku's avatar
        schumaku
        The problem is "just" the odd message on the WAX6xx console?
        tbozo wrote:
        I started to investigate on my WAX 610 because I had some issues with ACL that seems not to be recognized, ...
        Crystal ball is on a holiday in Transylvania. What ACL have you tried to put in place you suspect isn't processed and active?
        Sonos does require a workable STP configuration on -all- LAN switches, especially when "Sonos wireless" networks are connected to the LAN. Easy if users own switches allowing to configure STP to the book - impossible however eg. on consumer routers with LAN ports. What was brilliant in times where one Sonos wireless network is connected to a single Wi-Fi router is becoming a burden for many non-network engineers where multiple access points are connected to a wired network aka. LAN.
        Sonos Support: Configure STP settings to work with Sonos
        The key point here (tough Sonos fails to help their customers, they do a disservice) that some of the Sonos devices are creating a (unasked) what Sonos names a wireless network .... technically more a wireless Mesh network. Not all Sonos devices with Ethernet LAN ports are supporting this magic "Sonos wireless" while various newer Sonos models don't support it, as documented Switch Sonos between a wireless and wired setup - the selection is mutually exclusive.
        Yes, something to share with Netgear support only.
  • schumaku's avatar
    schumaku
    A long standing (15 years, or more) open source issue. Experience any issues with the WAX610 or 620?
ProSupport for Business
