JakeJ
Oct 31, 2023Aspirant
WAX620 NAT mode is terribly unstable and unusable
WAX620 with firmware V10.6.1.1 I'm trying to set up a guest wifi using NAT configuration. Connecting to the SSID with NAT enabled, strange network behaviour is observed. Initial connection opening...
JakeJ
Nov 07, 2023Aspirant
Still BUGGY.
I switched back the setting to
SSID1 main network
SSID2 NAT guest network
then I started observing unstable connections on NAT SSID2 again.
DHCP leased addresses : ok
Nameserver: ok
Measured throughput: ok
Youtube playback stuttering.
Opening web pages super slow.
Sometimes good, somtimes bad.
I just suspect NAT router in the accesspoint is overloading or
doing too much extra work.
Anyway I hope the future firmware release will solve it.
Thanks.
JulienR
Nov 08, 2023Administrator
Hi JakeJ,
I will ask a member of our support team to get in touch with you.
Thank you.
Best Regards,
Julien R.
- ESGRNov 08, 2023Initiate
Please keep us updated if a solution is found to this. We are having the same issue. 2 WAX620's. One on first floor, one on second floor. I have set up a guest wireless on a VLAN through a Sonicwall TZ370. It does work but seems to be dropping clients consistently. When I log in to Insight, the connection by SSID graph literally looks like a saw tooth with all SSIDs going from say.......5 clients connected to 0, then back to 5 again. We also have clients on the first floor randomly deciding to connect to the second floor WAP, which is odd.
I have tried all sorts of settings changes. Running firmware 10.6.1.1. Tried dropping power level to half on both WAPs, changing channels and bandwidth to create separation. Nothing seems to be helping.
- schumakuNov 08, 2023Guru - Experienced User
Obviously not the same.
JakeJ does talk of the NATed SSID option, allowing to have a small isolated Guest IP subnet by each AP.
In your deployment, it appears you have an issue on one VLAN spanning all WAX6xx, with the L3 done on the Sonicwall. At the same time, there are no problems with the normal LAN or VLAN handling the non-guest network(S)?
Apologize,
I will create a new thread.
