JakeJ
Oct 31, 2023Aspirant
WAX620 NAT mode is terribly unstable and unusable
WAX620 with firmware V10.6.1.1 I'm trying to set up a guest wifi using NAT configuration. Connecting to the SSID with NAT enabled, strange network behaviour is observed. Initial connection opening...
schumaku
Nov 08, 2023Guru - Experienced User
ESGR wrote:
Please keep us updated if a solution is found to this. We are having the same issue. 2 WAX620's. One on first floor, one on second floor. I have set up a guest wireless on a VLAN through a Sonicwall TZ370.
Obviously not the same.
JakeJ does talk of the NATed SSID option, allowing to have a small isolated Guest IP subnet by each AP.
In your deployment, it appears you have an issue on one VLAN spanning all WAX6xx, with the L3 done on the Sonicwall. At the same time, there are no problems with the normal LAN or VLAN handling the non-guest network(S)?
ESGR
Nov 08, 2023Initiate
Apologize,
I will create a new thread.
