aguden_guden_co's avatar
Sep 03, 2021
WAX630 - Installed but set up 2 wifi networks in errot
I added 2 WAX6302 and when I did I created 2 separate WiFi networks in error.  I wanted them to both be in the same wifu network.  How can I change that?  New to this concept of WiFi networks and I am sure my next question will be about mesh networks!
  • Alternate to Insight (not available in all countries, small cost, ...) it's possible to manage the WAX individually. On Management > Configuration > Wireless > Basic you can select the SSID you intend to change, then change the name, security PSK, ... to the same value like the other access point.
    • schumaku's avatar
      schumaku
ProSupport for Business
