Brian86
Jan 21, 2023Tutor
WAX630 deauthorizing printer connection
I started upgrading my network last summer by adding a new WAX630 WiFi AP. At which point I started having problems printing to my Epson ET-2760 printer over WiFi -- I could print right after turnin...
Brian86
Feb 04, 2023Tutor
Note, I found https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230, which seemed like a similar issue where, "the network drops the connection to an Apple iMac." I've tried the fixes suggested in the post but they didn't help.
- matt7277Feb 06, 2023Guide
Had very similar issues with my HP OfficeJet printer (would say connected but wouldn't be usable after a while, requiring printer reboot to fix it). Examined the logs and also noticed a TON of Deauth messages for the printer and other devices. Tried everything under the sun (disabling InstantWiFi optimization scans, increasing the frequency of InstantWiFi optimizations, using specific channels, disabling 5ghz/6ghz for certain SSIDs to no avail. Ended up break out some old equipment and now my 2 WAX630Es are expensive paperweights. Really surprising that this is still an issue as (IMHO) these types of bugs are total deal breakers and make the products unusable
