chickpea2247
Jun 28, 2025Aspirant
WAX630E Daily Disconnection Issues
Hi. I am having daily disconnection issues with my WAX630E using 2 separate laptops. Here are the logs of the latest disconnection:
Jun 28 16:13:47 nddmp[5337]: alarm : seqNo-[101], level-[OTHER], info-[{"ip":"192.168.2.226","mac":"9C-B1-50-FC-8F-F0","hname":"Caprica","txR":"58.50 Mbps","rxR":"154.90 Mbps","ssid":"@Pegasus-3","dOs":"Windows OS","dType":"Laptop/PC","mode":"11AX","status":"Authenticated","bssid":"E0-46-EE-06-FF-41","chnl":"1","chWidth":"20/40 MHz","rssi":"49","state":"QOS/ERP/HT/HE","type":"wpa2","idle":"0","time":"00:00:00","txB":"1702","rxB":"62","pmf":"none","vlanID":"1","Username":"Not Applicable","radio":"0"}]
Jun 28 16:13:46 nddmp[5337]: alarm : seqNo-[100], level-[INFO], info-[Pegasus-AP1: Caprica (9C-B1-50-FC-8F-F0) connected to Pegasus-3 with an RSSI -56dBm]
Jun 28 16:13:46 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 WPA: pairwise key handshake completed (RSN)
Jun 28 16:13:46 configd[5079]: 18391: error in fetching sta details for mac = 9C-B1-50-FC-8F-F0, iface = wifi0vap0
Jun 28 16:13:46 configd[5079]: Authentication Failed for client 9C-B1-50-FC-8F-F0
Jun 28 16:13:46 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 WPA: received EAPOL-Key frame (4/4 Pairwise)
Jun 28 16:13:46 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 WPA: sending 3/4 msg of 4-Way Handshake
Jun 28 16:13:45 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 WPA: sending 3/4 msg of 4-Way Handshake
Jun 28 16:13:45 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 WPA: received EAPOL-Key frame (2/4 Pairwise)
Jun 28 16:13:45 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 WPA: sending 1/4 msg of 4-Way Handshake
Jun 28 16:13:45 hostapd: send_garp: Index for interface br-lan is 53
Jun 28 16:13:45 hostapd: handle_assoc_cb: Marking client's assoc state as 0
Jun 28 16:13:45 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 IEEE 802.11: associated (aid 2)
Jun 28 16:13:45 hostapd: wifi0vap0: STA 9c:b1:50:fc:8f:f0 IEEE 802.11: authenticated
Jun 28 16:13:45 nddmp[5337]: alarm : seqNo-[99], level-[INFO], info-[Pegasus-AP1: Caprica (9C-B1-50-FC-8F-F0) disconnected from Pegasus]
Jun 28 16:13:45 nddmp[5337]: alarm : seqNo-[98], level-[INFO], info-[Pegasus-AP1: Caprica (9C-B1-50-FC-8F-F0) could not obtain IP address]
Jun 28 16:13:45 hostapd: wifi1vap0: STA 9c:b1:50:fc:8f:f0 IEEE 802.11: disconnected
Jun 28 16:13:45 hostapd: wifi1vap0: STA 9c:b1:50:fc:8f:f0 IEEE 802.11: disassociated
Jun 28 16:13:45 hostapd: wifi1vap0: STA 9c:b1:50:fc:8f:f0 IEEE 802.11: Station deauthenticated due to reason code 1
Current firmware: V10.8.13.2
1 Reply
- chickpea2247Aspirant
Apart from the disconnection issues, I have been having a separate issue - when using PoE ethernet port and powering the access point via PoE port on 2 separate Netgear Cloud Managed Ethernet switches.
When connected to a 2.5 GBit PoE port on my NETGEAR MS510TXUP - the port drops to 1 GBit speeds after initially negotiating 2.5 GBit speed.
When connected to a 1.0 GBit PoE port on my NETGEAR GS108Tv3 - the port drops to 100 MBit speeds after initially negotiating 1.0 GBit speed.
