janngobble
Oct 15, 2023Tutor
WAX630E Port #1 (2.5gbps) won't negotiate 2.5. Defaults to 1gbps on 2 diff switches!
Hi all, I have a WAX630E and am using all CAT6 or CAT7 cabling. I have a Netgear GS110MX and 3 Asustor 5 port 2.5G ASW205T switches. The WAX630E is plugged in using the power brick that came with i...
janngobble
Oct 16, 2023Tutor
Yes. (and no I'm not offended you asked).
Port labeled 1 with a lightning bolt is the 2.5gbps port that also accepts POE+/++.
That's the one I tested. For giggles (not really) I have tested the other port #2 as well.
Thanks!
Jann
Oct 16, 2023Guru - Experienced User
Just thought I'd ask 🙂
You'll have to wait for the guys who usually watch the business class stuff to help. I don't have any of the business class equipment to see what settings could be changed.
Good luck!
